Push PTO switch to OFF. Carefully trace the blue wire from PTO clutch to PTO switch. Likely you will find an abrasion of the insulation allowing contact with chassis (battery negative). You can verify PTO blue wire is shorted to chassis with an ohm meter or use an incandescent automotive test lamp referenced to battery positive.
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
No it isn't hard to change. But before you do, check the wire connection at the pto clutch it's self to make sure it is making a good connection. George
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
