2000 Nissan Xterra Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 nissan xterra knock senor and plug 5
2000 nissan xterra running rough idle. Not alot of power. Code says number 5 plug and knock senor. Changed the number 5 plug and spark plugs. Still same problem
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
5695
Points
8
Have you changed all the plugs to platinum and wires? My xterra was doing that and I changed all of them and now it runs great. Also, I changed the distribitor cap and rotor button.
HyeProfile
Level 2:
  • Expert 35 Answers
  • Posted on Aug 04, 2009
HyeProfile
Expert
Level 2:
Answers
35
Questions
0
Helped
40902
Points
100
Change your oxygen sensor. They're due...
My 03 Nissan Xterra is idling weird. It starts fine then goes into a cycle of rpm loops where it climbs to 1800 and drops to 1300 and keeps surging. I ran the codes and got p0328, p0174 and p0420. Any...
po328 is a knock sensor code ,0174 &0420 are emissions codes. Possibly a faulty knock sensor throwing out the timing, It may just have a vacuum leak causing it to run lean, affecting the timing causing knock sensor code, Scan for live readings, ck knock sensor, o2 sensors, A/F ratio & converter,clogged injector ect. Good luck
y
2answers
2000 nissan xterra 3.3 v6 starts but wont stay running at idle and runs rough. no power
could be many things,but i'd check airflow meter first,then fuel pressure and volume
Code 0304&0505 skips runs better after idle
Trouble Code: P0304
Cylinder 4 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCV system.Base engine mechanical fault that affects only Cylinder 4.Fuel delivery component fault that affects only Cylinder 4 (i.e., a contaminated, dirty or sticking fuel injector).Ignition system problem (coil or plug) that affects Cylinder 4.Trouble Code: P0505
Idle Air Control, Auxiliary Air Control Valve Circuit Malfunction
Possible Causes:
IACV-AAC valve control circuit is open or shorted to ground.IACV-AAC valve control circuit is shorted to system power (B+).IACV-AAC valve is damaged or has failed.PCM is damaged or has failed.
2000 nissan xterra~ feels like i got watery gas (checked, no) or running out of gas (not). sputters and jerks and loses power badly until can push gas pedal to floor and won't go above 5 mph. first time it...
Mass air flow sensor might be dirty or failing.
Clean sensor when cold with mass air sensor cleaner only.
that controls the throttle opening and closing.
2000 Nissan Xterra, v6 4x2 automatic. have a problem had code po325, and po306 come up, the car will not start. changed the spark plug, distributor cap and rotor. the xterra trys to turn on but it sounds...
You got a timing chain
Injector cleaner,in my opinion is a waste of money
PO306 could be a missing coil on cyl #6,still should start
PO325 Knock Sensor-most likely okey
Plugs,cap and rotor,will not prevent it from starting,it used to run with old parts, before the current problem!
I suggest you make sure you got the plug wires on correctly and number them with a ball point pen,on both ends.
Make a diagram of the dist cap wire locations.
Check out the TPS Sensor and make sure you have all intake ducting in place. You need the MAF Sensor in the system to run have it run
Have you checked fuel pressure? The pump may be going bad
2000 xterra changed the knock sensor and now putting up a 505 code
CODE PO505 - IDLE SPEED CONTROL SYSTEM MALFUNCTION.SOUND LIKE IDLE SPEED CONTROL ELECTRICAL CONNECTOR IS DISCONNECTED OR HAS FAILED.
2answers
1helpful
Rough running engine at temp
0340 is camshaft position sensor and the other 0325 is the knock sensor. Chances are you need to replace the sensors and good to go.
25helpful
4answers
Nissan xterra knock sensor
It's the valley of the engine underneath the intake manifold. It's about an $800 job because the top of the engine has to come off. However, unless you have a supercharged xterra it shouldn't effect performance. Also, the knock sensor will not trip the check engine light, as it does not indicate a primary problem, so if your light is on you should have another code that should be fixed first.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
