Washer drips after cycles are completed.
yes the water inlet valve is bad! might be easier to remove the base, when you remove the base the back stays connected to the frame. just unplug the machine,remove the end caps on your control panel and remove the screws holding it on, them pull slightly forward and up to fllip the control panel back it has plastic hinges on top,be careful not to break them. then unplug your lid switch, with a screwdriver remove the 2 gold clips that hold the base to the back panel, then open your lid lift from back towards you and the whole base will come off leaving the back panel and frame, should be a whole lot easier to replace the valve, then replace reversing your steps , when you are lifting off the base look at the bottom of machine through your lid and you can see how to put it back on the frame! not to hard!
