This could be one of two things. We will first start with a wheel bearing. When you are driving, does the growling noise get louder as you go faster. Some times is will sound like you have a helicopter flying beside you depending on how bad the bearing is. The second thing that could be causing the growling noise is your transmission. There are also bearings inside your transmission that could be causing the noise. If you have a cvt transmission, you have a 120,000 mile warranty and can have it repaired at no cost to you. You will just have to go to a nissan dealership.
Hi. Do you hear the growling noise only when the car is in motion? Or does it make the noise while you are stopped?
SOURCE: when I let off the accelerator on my 2009 Nissan
ITS A NEW CAR WHY ARE YOU ASKING ANY OF US ABOUT IT
GO BACK TO THE PLACE YOU BROUGHT IT FROM AND TELL THEM TO FIX IT FREE OF CHARGE in fact get another car while there Playing around with it AS ITS UNDER WARRANTY
Dont let them pull the wool over your EYEs take it back NOW Ron
SOURCE: How do you program a key fob / transmitter for a 2009 Altima?
all keys/car have to be programmed at the same time.using nissan diagnostic machine.you could try a quickfit centre (if they have correct machine)
SOURCE: 1999 Altima: My 1999 Nissan altima is making a loud whining noi...
you call it the serpentine belt, we call it the fanbelt.it,needs tightening,slightly loosen the alternator, then pull away from engine and tighten belt, tight enough when you can move longest part of the belt, between pulleys, 1/2 inch in/out.
if squeel re occurs fit new belt.
