Vtech Cordless 6041 Phone Logo
A
Anonymous Posted on Feb 18, 2014
How to set from pulse to tone on vtech 6.0 - Vtech Cordless 6041 Phone
1 Related Answer
  • 102366 Answers
  • Posted on Aug 26, 2011
SOURCE: phone changed from tone to
There's a switch on the bottom of the base unit to switch between tone and pulse. It's marked "18" in the illustration on page 6 of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/1249/UserManual/2839/vt2461_manual.pdf
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Should tone or pulse be set on cordless phone?
Tone, unless your landline company is using antique equipment which only allows pulse dialing.
How to change a vtech phone to tone
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual. The manual will explain how to switch your phone between pulse and tone dialing.
Phone changed from tone to pulse. there's no switch on the base to change from tone and pulse so how can i change this. vtech 2461
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Can't dial out,
It sounds as though your system is set to pulse instead of tone, look for a switch on your phone to indicate pulse or tone, change to tone.
Dan
How to change from pulse dialing to tone on vtech 5.8GHz
Here are the instructions for one vtech phone (may not be quite the same as yours but may work or give enough hints for you to figure it out):
Press PROG.•
Press ? or ? until the screen displays DIAL MODE: and the current setting.
Press SELECT. The current setting blinks.
Press ? or ? to select TONE or PULSE.
Press SELECT to save.
10helpful
2answers
My VTech 2461 cordless phone is stuck on Pulse
To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
11helpful
Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
VTECH VT-2406 TONE- PULSE SETTING ?
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=373
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
