ck to see what hydraulic oil your using , I bet it's an all weather rated oil, if temp is below zero then that's out of "all weather" range , you will need to look into using a cold weather rated oil (ck with you local dealer to ask ), my tractor has an oil bypass lever you can engage on the valve block this allows oil to circulate around in loop to heat up (+20 degrees) to work in cold temps , I don't think a 856 has one of them
You broke linkage inside on rockshaft when you pulled off the right lift arm. Sorry. Pull top hitch off and repair. There is a procedure to replace these seals safely without moving rockshaft side to side.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs.. 1.Check the thermistors (1) Check if the connectors are disconnected. (2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly? (3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken. (2) Check if the connector of the IH coil is disconnected. (3) Check if the thermostat is blown. (4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector CN455/456). (5) Check if the IH board or the switching power supply unit are abnormal. • Replace the IH control board.
3. Check the LGC board (1) Check if the connectors CN316 are disconnected. (2) Check if the conductor pattern on the LGC board is short circuited or open circuited. (3) Replace the LGC board. please vote me. Thanks Best Regards
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Hi how are you this is jack ...([email protected])..
Dear follow the procedure [C440] Fuser abnormality after abnormality judment. When this code not cleat 08-400 then check these all thengs.. 1.Check the thermistors (1) Check if the connectors are disconnected. (2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly? (3) Check if the harnesses of the main and edge thermistors are open circuited. 2. Check the IH board and IH coil (1) Check if the IH coil is broken. (2) Check if the connector of the IH coil is disconnected. (3) Check if the thermostat is blown. (4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector CN455/456). (5) Check if the IH board or the switching power supply unit are abnormal. • Replace the IH control board. 3. Check the LGC board (1) Check if the connectors CN316 are disconnected. (2) Check if the conductor pattern on the LGC board is short circuited or open circuited. (3) Replace the LGC board.
please vote me.
Thanks
Best Regards,
1,2.3. Check the thermistors, IH control board, IH coil and LGC board Check the above components following the procedure 1, 2 and 3 for [C41].
4. Clear the status counter Change the current status counter value (08-400) “4” to “0” for [C43] and “5”, “7” or “9” to “0” for [C44], taking the same procedure as that for [C41]. * The status counter value is as follows in the following cases. Change them to "0" respectively. • The error occurred during warming-up: "4" or "5" • The error occurred after the machine has become ready: "6" • The temperature detected by the center thermistor is 230°C or higher: "9" • The temperature detected by the side thermistor is 270°C or higher: "9"
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it. GOOD LUCK Mike
For error code C44, it indicates Heater abnormality.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
