Question about LG LMV1813ST Microwave Oven
DO NOT HEAT UP - LG LMV1813ST Microwave Oven
Why won't heat on inside although hot air comes out on side of microwave?
Oven cleaner should not be used on a microwave oven.
May 02, 2015 | Microwave Ovens
No Heat
The microwave sends out a strong radio frequency burst that vibrates the water molecules in your food and causes them to heat through friction.
No heat means no rays..means a new microwave! Cheaper than fixing..go to Craigs list
Mar 18, 2014 | Sharp R-1610 Microwave Oven
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
No heat from dryer, drum still goes round but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 13, 2011 | Microwave Ovens
Timer functions, fan works, great humming noise, no heat. Magnetron??
If there is no heat at all, but you can hear the magnetron humming, it is probably bad. if there is uneven heat, the wave stirrer that distributes the microwaves around the cooking chamber may be bad. it will heat only one spot unless the wave stirrer is rotating.
Nov 20, 2010 | Maytag MMV5207 Microwave Oven
I dont know how to use induction cooker.it has no numbers to reduce the heat.things will burn very fast
You can use to set the timing in order of the heat required. Also using the grade rating of the heating coupled with the time set, the food can be easily heated without burning.
To start with use low heat and long time, the try with medium heat and lesser time and then choose high heat and short time. You must be able to use the settings accordingg to your requirement.
Hope this advice helps
Aug 27, 2010 | Microwave Ovens
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMV1813ST Microwave Oven Logo
62 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
