RCA L32HD32D 32 in. LCD HDTV Logo
i
itsjustmehun Posted on Feb 18, 2014
Black Screen I connected my pc to my RCA TV but after the windows boot up screen I get a solid black screen. I tried connecting using an HDMI and an HDMI to VGA adapter. My pc connects fine to my Sony Bravia TV. Thanks.
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on Apr 05, 2009
SOURCE: no sound and picture not full screen when connected to pc
if you have your tv connected to your pc with a vga cable, you will not get sound, since the vga does not carry sounds, only pictures. to change the settings on your pc to make full you will have to change your resolution size on your pc in your control panel
Anonymous
  • 105 Answers
  • Posted on Jun 23, 2009
SOURCE: i can not connect my rca dlp HDTV to my hp laptop.
A lot of TVs only accept limite PC resolutions. Try 1028x768 60hz this normally works.
The Error message doesn't mean the TV or PC is not working, only that the signal is not compatible. try all resolutions until something works.
Anonymous
  • Posted on Aug 02, 2009
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
bshldn
Loretta Northcutt
  • 736 Answers
  • Posted on Apr 27, 2011
SOURCE: This RCA L26HD31 TV has
Make sure you have set the laptop's display properties to as low a resolution as possible (also make sure the screen refresh rate is 60 hertz) and turned it off before connecting it to the television. Turn the television on first and set to the correct input either hdmi 1 or 2. Then turn on the laptop. When it has booted up hold down the function key and the dual monitor key (either F5 or F8) for 15 seconds for an image to appear on the screen. When you have an image you can play around with increasing the laptop's resolution.
Anonymous
  • 46 Answers
SOURCE: Cannot connect my pc via hdmi to an RCA L26HD31.
If your trying to use a computer with a video card that is not HDCP capable it will not work.You'll need to replace the video card that has hdcp .You can thank Hollywood for that.Hope that helps
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3answers
Can you help with my RCA Home Theater set up?
Doesn't the manufacturer have a toll-free help line that you can call with questions? Try this RCA phone number: 1-800-968-9853.
Rca 10" tablet need to connect to my phillips tv.Plug up nothing happens,Took a hdmi/rca cable from camera, hooked tablet to tv that made my tablets screen go black until unpluged from the tablet.
Screen going black usually means it is connected to another screen. Is there a setting on the tablet to enable output settings and a setting on the TV to enable input settings.
Partial black screen on mulitple (but not all) inputs on panasonic plasma tv
Sorry but it's time to shop for another tv the cost of repairing would cost almost as much as a new unit.
Panasonic tx p50u30b Black/Blank screen
Might be a resolution issue. Make sure the resolution in windows for that monitor is set to 1920x1080.
Aspire 5920g black screen connected it to tv with
What version of windows are you running? If you hit the Windows Key (typically between the ctrl and alt keys) + P you can cycle through the display modes. You may have it set to computer only, however Win Key + P will change the mode. Try setting ti to Duplicate, Extend, or Projector only.
Step by step instructions how to connect acer c7 chromebook to tv using hdmi cord
Try pressing the Pearl Button or the windows button in your keyboard + P. The display options will show up, just select the extend or duplicate.
I hope this helps!
David
Hi I'm trying to connect my laptop to play photographs through the TV screen using windows XP. No success at the moment. How do I connect up please? And can i get a manual for the TV anywhere...
For making the physical connection between PC and TV first we need video cable.
PC has S-Video port that should be connect to the S-Video input of your TV using S-Video cable.
Connect the computer to the TV using VGA ports or via the DVI to HDMI cable. These Macs need Adapter for a VGA cable.
RCA for audio, connect RCA to your PC and red and white colored sockets of RCA cable to TV (left audio-white, right audio-red).
In your PC open the Display Settings and activate output to the TV screen.
In your TV open the menu from that open the External inputs. And change the video to HDMI depends on the connection.
You can also change the screen resolution of your TV using the Personalize and Display Settings options in your Control Panel on PC.
After giving the connections you can watch the movies and everything is running on laptop on TV.
1helpful
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
