It is a belkin N450DB IT has an orange light and will not turn blue no matter how many times i reset it. and when i called to the customer service they want to charge me
Hi Christopher s crisp,
Is it blinking Orange or steady?
Blinking amber: The Router can't detect the modem. Either the
modem is off, is not plugged into the Router, or is unresponsive.
It could be the modem.
You can try connecting the modem directly to computer bypassing the router and see if that works.
Check the LED on Modem.
Do you have other computers to test the connection?
Might need to talk to ISP if issue with Modem.
Let me know.
Thanks
SOURCE: Modem Light Blinking Orange
I wouldn't be too concerned about that. Probably just does it when it is adjusting.
SOURCE: Belkin F5D8236-4 Wireless Router will not connect
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
