Frigidaire FRS23H7CS Side by Side Refrigerator Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water dispenser not working & fridge and freezer not getting cold
We have a frigidaire sxs model that looks like the gallery models. We are just past our one year warranty and it was working earlier today, but tonight the water dispenser will no longer dispense water, and the freezer and refrigerator are warming up. It seems strange that both problems would happen at the same time. All lights still work, and you can hear something running, but I cannot be certain if it is the compressor or the fan. I think it is only the fan though. So I would assume our compressor may be out, but then why isn't the water working?
  • jacquelyncup Jun 10, 2009
    I meant to include the model #'s:
    frigidaire model type: JSI-26
    model# FRS6R3JWO
Anonymous
Level 2:
Novelist:
  • Expert 145 Answers
  • Posted on Jun 10, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
145
Questions
0
Helped
65001
Points
441
Okay, most likely, your problem is your fan motor, its making your evaporator becoming a block of ice freezing your water lines but its not circulating the cold air through your refrigerator. remove the panel from inside the freezer and see if it has become a big white block of ice and the fan motor is turning. some fan motors will not work with the door open so you must manually press the light switch and see if the fan is blowing air.
if fan blades are not turning, replace the fan motor. but if it is blowing air and there's a big block of ice, unplug your fridge and let it thaw out. if after melting your fridge is running again, there's something wrong with your defrost system. that means check and replace your defrost heating element, defrost thermostat and or defrost timer.
i hope that helps with your problem. good luck!
Replaced water filter, dispensing valve on frigidaire gallery side by side still no ice or water
It may very well be frozen. Some of those fridges have problems with the line freezing because of the way the line runs. The one way to tell would be to empty fridge, unplug, and let sit to thaw. Opening freezer/fridge doors will shorten the process. You can Google your exact model number also, and find out how your lines run and use a hair dryer on that location.
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Fridge wont get cold
Check your brakers, on your house braker panel, it should be a 20 amp, pust it all the way off, then all the way on to reset
1helpful
Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
1helpful
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
1helpful
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
1helpful
Refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
