2001 Hyundai Accent. Problem started the day after we replaced belt. Car will run fine for about 30 miles. Temperature gauge is normal. All of a sudden gauge hits top and car stalls. Makes clunking noise. Has go get way cool to run properly again. No water in radiator but no visible leaks either. We have already replace thermostat.
YOUR WATER PUMP GASKET IS LEAKING.ITS NOT SEALING.IF YOU DID USE GASKET SEALANT ON WATER PUMP GASKET IT WILL LEAK.ALSO YOU NEED TO PUT HALF ANTIFREEZE AND HALF WATER.BECAUSE WATER WILL BOIL OR EVAPORATE.WHEN ENGINE TEMP GET ABOVE 212.YOU NEED ANTIFREEZE TO RAISE THE BOILING POINT.SO YOUR ENGINE WILL NOT OVER HEAT.EVERY TIME ENGINE OVER HEAT IT DAMAGING THE TRANSMISSION.I WOULD FIX IT.QUICKLY.CHECK TO SEE IF WATER PUMP LEAKING.YOU MIGHT HAVE TO REMOVE AND REPLACE THE GASKET AGAIN.
If the water tends to keep going down then there has to be a leak somewhere. Try also looking at the hose coming from the overflow tank and see if the hose might be kinked. You might also be blowing antifreeze out the tailpipe. Take a look and if there is bluish white smoke then you have confirmed that theory,
hotchevy1965, we didn't replace the water pump, we replaced the thermostat.
chuckie12_87, there is no smoke, no water in oil or oil in water.
