NASCAR radios are not digital & besides, your scanner can't be upgraded. Try programming your local NOAA weather frequency. If you can't hear it, your scanner is not functioning properly & it's doubtful that it would be worth the cost of repairing it.
Your scanner does not receive frequencies between 54 and 137 MHz, and there's nothing you can do to enable reception in that block. Your only option is to purchase a scanner with air band coverage. Here are the reception ranges of the BC-60XLT-1:
29.0-29.7 MHz 10 Meter Amateur Band 29.7-50 MHz VHF Low Band 50-54 MHz 6 Meter Amateur Band 137-144 MHz Military Land Mobile 144-148 MHz 2 Meter Amateur Band 148-174 MHz VHF High Band Above bands in 5 kHz steps 406-420 MHz Federal Government 420-450 MHz 70 cm Amateur Band 450-470 MHz UHF Standard Band 470-512 MHz UHF "T" Band Above bands in 12.5 kHz steps
Need the manual for your scanner? You can download and print it, at no cost, here: http://www.uniden.com/pdf/BC60XLT-1om.pdf
you need a USB to scanner interface and a program like w95.exe to ytransfer freq uencies to the channels. It;s a lot easier this way than laboriiously entering 1 at a time.
type w95.exe into berowser and download It's free but the transfer item cord is available from some ebay sellers Serial / USB transfer cable for bc60xlt
I have had also repeated problems with the gas gauge, speedometer cluster. I removed it and took it to an electical shop here in Kelowna, B.C. and they replaced a fuse in it. My led screen seems to only last above 3-5 months and then fries out again. I keep replacing the fuse and it still does it
