Dell Inspiron 1525 Notebook Logo
A
Anonymous Posted on Feb 18, 2014
Charger light not coming on anymore .is charger bad
Dell laptop inspuron1525 use to show a blue light on charge pack
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Nov 02, 2015
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
259122
Points
4510
5 Related Answers
Anonymous
  • 155 Answers
  • Posted on Jan 02, 2009
SOURCE: Charging problem
It's definitely the motherboard based on the symptoms. You can send it to their out of warranty depot. Or you can purchase the motherboard from their spare parts sales dept, then look for a local tech who can install it for you.
Anonymous
  • 82 Answers
  • Posted on Jan 19, 2009
SOURCE: battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Anonymous
  • 225 Answers
  • Posted on Oct 12, 2009
SOURCE: My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Anonymous
  • Posted on Oct 31, 2009
SOURCE: Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Anonymous
  • 1472 Answers
  • Posted on Jan 11, 2010
SOURCE: dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
2answers
Charger light comes on but laptop won't start or charge even with new battery it was working till i did a calibrate the battery
IF you are not using a Dell charger that is the first thing to try. They are proprietary and wont run the laptop in some cases involving the battery. There could also be an issue with the MOSFET power transistors that may have happened at the same time. This is not easy to check or repair.
2answers
My dell laptop isn't charging when plugged in. What should i do?
Dell chargers have a centre pin to allow the laptop to sense that the charger is a genuine Dell one. If the battery is not charging then:
a) Battery is faulty (old and dead)
b) Pin missing on the charger, wire broken or not original Dell device
c) Charging port on the laptop has become loose.
Hope this helps.
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
2helpful
2answers
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
1helpful
3answers
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
2answers
Loose charger connection
Hi Jon. it sounds like the DC power jack needs fixing or replacing.
go to this link and scroll down the page and have a read up.
laptop charger port hole broken Google Search
My N5010 dell laptop battery won't charge anymore. Could I just need a new battery, or charger, or could there be something else going on internally that I need to know about? For the most part, I
If your laptop is still under warranty, contact dell and they should be able to fix it free of charge, The same thing happened to my laptop a few years ago and fortunately, it is still under warranty, The fault is the charger itself which dell replaced free of charge.
2answers
For some reason my Dell Inspiron 1525 wont charge!!. I plug it into the main and the green light comes on the charger lead and it is putting power into the computer but just not actully getting any charge...
This only mean that you have a failing battery and does not hold charge anymore.. battery life can last upto 2years, depending on how frquent you use..
HOpe this helps
1helpful
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
10helpful
3answers
Dell laptop charger
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
