Question about LeapFrog My Pal Violet
Violet wont turn on - LeapFrog My Pal Violet
    New Friend:
One thing to check, especially if you are replacing batteries, is for corrosion on the terminals. I just replaced batteries in my daughter's Violet, and it wasn't working. When I looked closer, I found a couple of the terminal contacts had corrosion (looks like rust). I took a few Q-Tips with some white vinegar to clean them up until I could see metal on the contacts again. After putting the batteries back in, it worked fine.
Posted on Jan 27, 2015
SOURCE:
My sony experia mini wont turn on it just buzzes
May be one of these:
1) power module, defective or conector.
2) change the charger*
Carl
Sep 23, 2016 | Sony 256MB Classic Violet Micro Vault USB...
My pal violet's led light will not turn off. Is there a way to fix it?
what vehicle does violet drive maria , and which led are you refering too .Steve
Jun 16, 2014 | Cars & Trucks
Violet won't stop barking
Our violet was doing the same thing, as though the on/off paw was pressing all the time. I have just replaced the batteries, and it seems to have fixed it. In one of the manuals I read it says if she is behaving erratically, then replace the batteries, and that the included batteries are for display only. We only had her a month!
Dec 28, 2013 | LeapFrog My Pal Violet
My camera olympus 850 SW the lense turn on violet color thats why when im startng to video or take a picture its color is violet..
i don't have the solution but i experienced the same problem on my olympus 850sw
the images turns violet and the pixels are distorted
never see this kind of error ever a camera had
Oct 18, 2010 | Olympus Stylus 850SW Digital Camera
Need to know what wire colours r what on the harness of a Clarion DXZ635MP CD player lost manual
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
May 27, 2010 | Clarion DXZ655MP CD Player
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
I just bought a used dual xd6210 stero deck for my car but i dont have the wireing manual for it. i need the wire color code sheet
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
Jun 10, 2009 | Dual XD6210 CD Player
Violet screen on kodak m753
Check the White Balance setting. If it is on Tungsten or Bulb, put it on Auto.Also check if the lens is clean. Use a dry cotton cloth to clean the lens. If this fails to solve the issue, take it to the nearest authorized service center.
Feb 10, 2009 | Kodak EasyShare One Digital Camera
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
LeapFrog My Pal Violet Logo
298 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
