I dont have a instruction manual with my watch and I cant figure out how to set the time
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
