Looking for diagnostic help, 2009 R1200RT stalls while driving and in idle immediately after starting. Brand new battery, new clutch. Feels and sounds a little rougher than usual.
moved you out of cars, to BMW Motorcycles.
if I leave light (heads/) for 30minutes, (engine running or not)>??????
if engine not running, that is NORMAL
if engine is running that is AbNORMAL and Alt/Gen is dead or fuse blown..
no you have 2 problems?, GEN dead and injection issues.
the cold start fails for these reasons of vast.
1: bad fuel, filters clogged.
2:injectors partially clogged from #1
3: spark weak , plugs bad.
4: or starting it with a DEAD Gen that caused battery to be weak.
but weak batteries do not crank or crank slow. so.... or does barely and now spark is weak with 11v battery weak?
TBO, fix bad gen first so it says running and not flat line the poor battery. I guess you have battery charger and using it to hide the bad GEN sure.
in all cases for sure this , check all fuse for sure all related to GEN.
