Ok i took my computer apart to replace the motherboard fan and put another cd rom driver into it also added a 150 mb chip in it to and put another 40gb hardrive from a gateway computer but my computer is a northgate pc so i hooked everything bk up and turned it on and the moniter doesnt reckenize the pc .. yes i do have the connection hooked up from the monitoe to the hardrive but nothing happens so i took the battery out for bout 20 min then hooked everthing bk up still the same
Try taking the ram chip out then see if thats the prob by turning on the computer without it if its not, try unhooking the cd drive and then try turning on the computer if thats not it then try unhooking the hard drive and check if thats it one of those should be the problem i had the same prob but i messed with the ram chips and it worked i just took it out started it up and it worked if thats the prob just start it up then shut it down and put the ram chip back in and it should be fine
