- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
The most probable, as far as I know, the hard drive is dying. Please test the laptop with a healthy (or brand new) hard drive.
SOURCE: Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
SOURCE: how to turn on wirelss on a dell inspirion
Ok now firstly you have to see whch inspiron laptop you are acctually using. The procedure is same in most of the cases and here it goes... If you are uing somewhat older inspiron 1525 then there is a wireless switch on left side.just slide it to activate it. On newer inspiron 1540 wireless switch is on keyboard itself...Check out the F2 key.Its the one for wireless now...In some cases you might have to push Fn along with F2.
SOURCE: When I close my Dell Inspiron 1545 laptop, it
Check your computer bios settings. There is a power managment section. Turn off power managment or set it to os controled. Check dells support site for any acpi drivers that you may need. These are needed for suspending controls.
Hope this helps.
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
