Maytag Atlantis MAV6000 Top Load Washer Logo
Posted on Jun 10, 2009
Maytag Atlantis MAV6200AWW; Washer goes through wash cycle, but doesn't rinse or spin on first go round (timer/switch moves through cycles). Once the switch is moved back to the end of the wash cycle, it drains and refils but it doesn't rinse or spin. After several refils, we move the switch to the spin cycle for the fianl spin.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2521
Points
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Anonymous
Level 1:
New Friend:
  • Posted on Apr 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2521
Points
21
My washer is maytag bravos quiet 300 series It does the washing cyle well just when it get to the spin cycle it keep showing me the ul signal
I have a Maytag Atlantis MAV6200AWW top loader washer and it doesn’t’ drain unless you run it on spin cycle manually. How do I fix this?
Your timer is most likely bad. The timer is the part with the knob that you use to set the wash. Very easy to replace.
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
1helpful
Not draining after rinse cycle
replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
1helpful
Maytag mav6200aww washing machine doesn't rinse clothes
If you say this only happens on the Colors and Whites cycle i dont see what the lid switch or balance sensor (if your washer has one) would have to do with it. It does seem like it has something to do with the timer,,, it really sounds like maybe the (Colors & Whites) section of the timer is malfunctioning. Inside the timer, there are a series of gears and switches, and by slamming the lid, or tapping on the timer control knob,,, it could maybe help the damaged part of the gear move, temporarily "fixing" the problem
1helpful
2answers
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
