An ERR 2 may be cleared by a simple reset of the coffee maker. This
means unplugging the unit and plugging it back in. When powered back
on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the
warming plate. This may be covered under Kitchenaid's 1 Year Hassle
Free Warranty. I would advise you to call Kitchenaid Customer Service
to see what options are available to you. Repair is not recommended, as
it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
SOURCE: Kitchen Aid coffee maker err2
on, select a brew function to see if the error reappears. This may take a few seconds.
SOURCE: where can i buy charcoil filter for kitchen aid
Hello Ikring,
The filter that you are refering to is the ion filter it can be order from many different online stores. I have found one that the part number is KCM50WF sell the item for $12.99 for 2 and a $1.99 shipping. I asume that you already know how to replace the filter. You might also check your local hardware store as many of them also stock these types of filters. This is the link to the store and web page the item is on http://www.filtersfast.com/KitchenAid-KCM50WF-Coffee-Filter.asp
Thank you for choosing FIxya and please do not hesitate to ask more questions.
SOURCE: Error Message
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Thanks.
need new water filter for kitchen aid coffee pot
