If make outgoing calls and the person whom you're calling can't hear you,the main problem is the mic or mouthpiece that transmit your voice to others.
* this is due to when you dropped the phone and the components or parts are dislocated
* water damage that may result to corrrusion.
If you can fix it on your own :
(you need a T6 precesion screw driver)
*open the back cover by just lifting up the side housing * unscrew 2 screw then there's a small box insert with 2 pins and that would be the mic or mouthpiece we're looking for. *check the level of the pin and see if there's a stain or dirt,try clean it and align as well. * assemble it again and test using a voice recorder or try to call anyone.
hope it helps you with this solution..thank you for visiting Fixya...
you can try to use a headset and see if it will work
normally if the caller cannot hear the receiver theres some problem with the mouthpiece. if the headset and loudspeaker works then you have to go to the store and have it fixed.
hope this help
The problem with your phone is that the mouth piece on your phone is bad that is why people you call or people that calls you cannot hear you.
All you need to do is to replace the mouthpiece on your phone, after you have change the mouthpiece, you will see that people you call or that calls you can hear you while talking.
All you need do is just to replace the mouth piece of your phone and you see that people will start hearing you when you talk on the phone.
when you are on the phone and you can hear the person on the other side but they cannot hear you, this could be caused by twoo factors.
1. the network or 2. the mouthpiece of the phone,which is the tiny hole by the lower end of the phone.
if it is the network, the problem is temporal.
to find out if it is the mouthpiece, try using a earpiece or bluetooth device if your cellular supports that and see if the other person gets to hear you.
then you can tell if it is the mouthpiece and replace it.
The problem with your phone is the mouthpiece,since they can not hear you at the other end, the mouthpiece of your
phone is malfunctioning, that is why it works for sometime and not working again now.
Perhaps you might have hit the phone mouthpiece with a hard surface.
All
you need to do is to change the mouthpiece of your phone and you will see
that they can hear you at the other end.
