I had this problem and after 7 days I've heard nothing back from LaCrosse. Problem appears to be a non-functioning magnetic reed switch inside the circuitry housing. It's easy to remove the cover with a tiny phillips screwdriver (mind the small and delicate gasket/o-ring). Then the circuit board is held in with two more tiny philips screws at the bottom of the housing. Removing and replacing the switch will require a low-wattage soldering pencil. I used a Standex-Meder part number ORD228VL-1015 from Digi-Key. Only a couple $, cheap, fast shipping. It appears to be an EXACT replacement.
