SOURCE: rca 32 screen turns on but stays black
Theres no start-up signal being encoded, this means the interface board has an offset capacitive value. You need to test and measure the capacitors and npn/pnp transistors, along finding some open diodes too on the main board (interface). You have to test the capacitors under their operating voltage also to see at which point their breaking down. The problem is a 'load' condition on the main board. You can repair the board if your savy and you have test equipment or you can just replace the board. If you want to replace it e-mail me and I'll help you out....
SOURCE: dvd stuck in RCA widescreen tv
There are two things you can try to correct this problem on your TV/DVD combo unit:
Testimonial: "the information provided WORKED !! TNX MUCH"
SOURCE: I'm having double images with
You could try to go into the settings and use the "Image Cleaner" option. That's what we do with our tv. But i'm not sure if it will work with yours... (:
SOURCE: RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
