You can adjust MTU from within the Belkin Router administrative console. You really should not be changing it unless your current ISP gives you a specific MTU setting, otherwise you could disrupt internet connectivity.
Default IP address: http://192.168.2.1
Default admin username: Administrator
Default admin password: <blank>
Be sure to set a password for your router!
This is the address where you change MTU
192.168.2.1/wan_pppoe.html
Belkin Wireless G User Manual:
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=5999&scid=221
Windows Tools to adjust MTU:
DrTCP tool:
http://www.dslreports.com/drtcp
TCP Optimizer
http://www.speedguide.net/downloads.php
SOURCE: adjusting mtu settings
If you don't find a way to do this through the router, you could try downloading TCP Optimizer from Speedguide: http://www.speedguide.net/downloads.php
You can adjust MTU settings using this tool (select 'custom settings'). It affects the registry, so you'll want to backup & create a system restore point before setting it up.
SOURCE: I need to increase my MTU settings on my router for Xbox LIVE.
You can do that by configuring your router. Look for the default ip address of yoour router, it can be found in your router's manual. After you found it, run internet explorer and type in your ip address (ex. 192.168.10.1). There you o just enter your username and password and your on your way to the configuration process. Go to internet setup and under DHCP Internet Connection Type you can change MTU there. Just give it a try...
SOURCE: i dont know how to change mtu on my n150 belkin
the mtu table is this: http://www.juniper.net/techpubs/software/junos/junos56/swconfig56-interfaces/html/interfaces-physical-config5.html
and u can change like this:
on your wan config page is the mtu parameter u can change.
SOURCE: I am trying to connect to Xbox Live using a Belkin
Hi i got your issue I will assit You further......please try with the following steps
Step 1) Connect modem>>Belkin router>>computer
Step 2)Open the browser page
Step 3)Clear everything on the address bar and type http://192.168.2.1
Step 4)Checked towards the left coloumn....under INTERNET WAN click on CONNECTION TYPE-if asking for a password leave it blank and hit SUBMIT
Step 5) Select your connection type as PPPOE and hit NEXT
Step 6) You will get an option to change the MTU SIZE
NOTE: This can be done only if your connection is DSL
Please try with the above steps if you have any issues let me know it
Thanks ......
With regards.....
PRIYA
I have a Belkin router, and I could not find where to set the MTU. But I found a program you can use to set the MTU on your NIC adapter.
reset the router and follow this to change the settingshttp://fixingblog.com/why-belkin-router-...
http://www.askprob.com/forums/topic/why-...
