My HP J4580 all-in-one printer continues to display the message "Print cartridge problem [Tri-Color] Refer to device manual to troubleshoot. Nothing in the manual says anything about this error message or how to fix it. The cartridges are totally fine and full- I even put new ones in and this message was still displayed. How do I fix it?
To fix Print cartridge problem just dial our HP Printer Support Number 1(844)355-5111 and follow the steps given by our expert technicians with the help of customer support services.
HP Printer Support Phone Number 1 844 355 5111
This error ("Refer to device documentation to troubleshoot"), along with the famous "Incompatible Cartridge" error message, typically signifies the HP 901 ink cartridge is suffering from internal electrical (micro-electronic) damage. Our test labs have noted the Malaysian manufactured HP ink tanks, especially the XL tanks, seem to be more problematic/sensitive (vs.HPs Singapore/China manufacturing facilities). You can bypass these cartridge error (temporarily in most cases) and run a cartridge health diagnostics check, via the 2 service procedures below: HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4 HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE (please note this is a service test, the printer will attempt to print the tap 41 pattern, whether the cartridges are good or bad):
HP 901 Ink Cartridge Care Tips - Everything you need to know:http://www.youtube.com/watch?v=jTtNj6rN4g4
Lestave my j4580 trouble lt says ck blk cartrige
SOURCE: my printer says J4580 Print Cartridge Problem : [T...
my printer is not shutting down what must i do
SOURCE: J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
