Phone is turning itself off when or after recieving a sms message, then slow to reboot. then it will turn itself off again when trying to send a text or make a call after reboot. battery level falling to approx 6% after 2 to 3 reboot attempt. phone seems to work fine when it is on the charger.
SOURCE: My Touch phone will not send sms.
1. If you dont have a sufficient balance the message go to outbox to be sent
2. Check from your service provider that whether you have configure your SMS center number is correct. They will be able to tell you!
Best luck!
SOURCE: can't send sms from my HTC HD
Hi
The message centre number I believe is attached to the sim card. Try putting your sim into another handset and access message number on that and edit. When you move it back to HTC it should work. Hope that helps?
SOURCE: y cant i send picture messages or recieve them either from my g1
You need to have the interent package to do that. If you dont there are some settings that can bypass that:
Menu > Setting > Wireless controls > Mobile networks > Access point names
Once you get in there, scroll down until you see T-Mobile US and input the following settings:
Name = T-Mobile US
APN = wap.voicestream.com
Proxy = 216.155.165.050
Port= 8080
Username= None
Password = None (delete the 4 digit PW that is there)
Server = Not set (also delete the 1 digit PW there)
MMSC = Unchanged (do not change it)
MMS proxy = 216.155.165.050
MMS port = 8080
MCC, MNC, and APN type all stay they was they are.
Now as far as remembering the old information goes, you can always go into T-Mobile US 160 (right below T-Mobile US), which has all the same settings as T-Mobile US including the password. All you have to do is copy and paste it.
TAAA DAAAA!!!!
SOURCE: No alert when sending text message.
Start | Settings | Sound & Notifications (make sure Events is checked). Check out the Notifications tab, too for more control.
SOURCE: my sprint 4g evo wont
Go to Menu-> Settings-> update then update prl and profile. Reboot device if problem continues Go to Sprint
