Go under ur hood and disconnect the battery, let it stand for 30 minutes and reconnect (this will reset the check light), if it comes back on than u should get it checked out by a mechanic
if the light went off on its own. then the necessary criteria for the light being on has come back in to the allowable tolerances. if you can pull the history code, i can help you out. possible you got gas recently? check engine light will illuminate for a loose gas cap causing evap system malfunctions
my light went out after i replaced egr valve---twice--then came back on....then i had a fuel system "clean out" done by national chain...light went out--milage went up--GOD BLESS AMERICA!!
I had the same problem. I went to the kia dealer and they checked the code that caused the light to be on and found I had a leak in the gas cap. They replaced the gas cap and the problem went away. You night need to find out what made the check engine light go on in the first place.
