If u want to reset the ECU just unplug the battery for 5-10 mints then plug it back by this the memory in the ecu is erased , if not u have to reset it from a scanner
Although this will work, you may then need to reset your car radio if it loses all its presets and the PIN . An alternative is to remove the EFI main relay (in terminal block 1 near the air filter box) for at least 30 sec.Although this will work, you may then need to reset your car radio if it loses all its presets and the PIN . An alternative is to remove the EFI main relay (in terminal block 1 near the air filter box) for at least 30 sec.
You can't post conmments that contain an email address.
TOYOTA. Table of Applicable Models. ..... The orientation of the ECU depends on the vehicle with ECU pins. Install the ECU fully checking the .... 2MZ?FE. '97.5?'02.1. VEROSSA. JZX110. 1JZ?GTE. '01.8?'04.4. L. T10?b. HW?23.
Black smoke indicates running "rich" (using excessive fuel) sounds like an injector is sticking open. I would first run a strong fuel system cleaner through it. (Maybe even have a professional fuel system cleaning) Ques? When was last tune up? A dirty air filter would contribute, but not make alot of black smoke.
Here is a detailed solution on how to reset your 1992 camry;
1.Open the fuse panel cover in the driver's side footwell by pulling down on the fuse panel cover. 2.Locate the fuse for the electronic control unit, or ECU. 3.Pull the ECU fuse using the fuse pullers in the fuse panel. 4.Turn the ignition to the "On" position and wait five minutes. Then reinsert the fuse. The check engine light will blink several times before going out. This will reset the computer on your 1992 Camry Thanks..
its the ecu ,my camry had the same problem. one of the injectors is staying open and flooding the cylinder.changerd the injectors same problem,changed the ecu problem solved.
