I just updated my nokia 5310 firmware and now my memory card has locked itself.
can anyone help with this?
does anyone know the code?
you
can use the Nokia 5310 for many different storage and entertainment
functions. The mobile phone has the ability to save all of your large
files (such as pictures) to a memory card instead of using up all of
the built-in device storage. You may run into issues with the memory
card if it is locked. This can happen if you buy a used card or if
you forget the password that you programmed into the card at the time
of purchase. You can unlock the card with a default password, or you
can delete the option that requires the memory card from requiring a
password at all.
Instructions
1.
Power off the Nokia 5310. Put the memory card into the memory card
slot on the Nokia and then power on the device.
2.
Click the "Menu" key down from the main screen of the
5310. Select the menu option for "Extras."
3.
Navigate the cursor down to the bottom of the page. Press down on
the option for "Memory Card."
4.
Click the "Options" selection that appears as a screen
prompt. Move through the options until you reach the "Unlock
Memory Card" option. Click the cursor to select the "OK"
option.
5.
Manually enter in the unlock password with the 5310 keyboard in the
password box. When you cannot remember the password, the generic
passcode is "12345" or "1357."
1.
slot on the Nokia and then power on the device.Click the "Menu"
button down from the main screen of the 5310. Select the menu option
for "Fun & Apps."
2.
Scroll down to the selection for "Gallery" and then press
on the "OK" key. Navigate to the "Memory Card"
screen selection and then press on "Options." Move through
the list until you reach "Memory Card."
3.
Press down on the option for "Delete Password" when the
screen pop-up menu loads. Verify that the words "Memory card
will unlock now, do you wish to proceed?" appears. Select the
option for "Yes" to verify the unlocking.
4.
Navigate to the password box and manually type in the default
passcode. When you cannot remember the password, the generic
passcode is "12345" or "1357." Select the "OK"
key when you are complete to remove any passcode requirements from
the 5310.
