The portable disk's light comes on and there is a whirring sound coming from the disk but nothing shows up on the computer
SOURCE: Hitachi External Hard Drive (500GB) Beeping sound
Probably not. You can try putting it in the freezer overnight (in a bag please, don't get moisture in it) but most likely if you must have the files back it will take professional help.
SOURCE: A new hard disk drive, Hitachi part
Hello there DLBurkhart.
Here's your geek-steer ...
"...is emitting strange whining sounds every now and then ... Is this strange noise a sign of an impending problem?" == EVERY strange HDD noise is ALWAYS a sign of impending failure.
Peform a "Check Disk" on it ...
chkdsk DRIVE_LETTER /X /R
Good luck, and please do post back ...
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Testimonial: "Straightforward advice, actually reads the problem pays attention to what you say rather than skimming and throwing out half-hearted recommendations."
SOURCE: how to use hitachi simpletouch external 320gb hard
Hello
If the HHD gets power and you can feel the drive spinning, you can try these steps and see if your problem is solved. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
If you cannot see any power light flickering or feel movement on the drive when you power it up, then there is a other problem. Hope this can help you.
Best regards
Andrea
SOURCE: hi, my external hard drive recently cannot be
Hi there
I dont know if this will work for you but looking on the web I came accross someone who had a similar problem they fixed it as follows.
They installed Tweak UI and then
She was able to get the drive recognized using "Tweak UI", clicking on My Computer, Drives,and check marking Drive F. It did the trick.
Hope this helps software link for you
http://www.annoyances.org/exec/show/tweakui
SOURCE: hard disk not recognised
When a hard drive makes a clicking noise, it is faulty. The clicking noise is the heads swinging back and forth. This hard drive is dead and the data is lost. If you desperately need to recover your data, there are companies that can recover and copy your data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Testimonial: "is there any to tto got it corrected?"
