Question about JBL MR-17 Sirius-Ready AM/FM/CD Receiver Controller
I can't find whether or not The JBL MR-17 will
I can't seem to find out whether The JBL MR-17 will play mp3 CD's or not. Thanks.
    Problem Solver:
  • 9 Answers
It Does Not. Only standard CDs the manual is here:.http://www.prospecelectronics.com/JBL%20MR17%20manual.pdf
Posted on Jun 28, 2009
  • 909 Answers
I have looked at several sites and none say that they do so I assume they don't.Also if a player does it normally says on the front.
Posted on Jun 09, 2009
SOURCE:
I have a jbl mr17 radio and i want the clock to stay on
Clocks are usually wired into same circuit as your dome/interior lights, so they have constant power, regardless whether key is on or off.Should be able to find a wire to splice into around your fuse box.
Nov 01, 2011 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Won't read the CD's now
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
Jun 01, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Car Audio & Video Logo
348 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Marvin
Marvin
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
