Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
A
Anonymous Posted on Feb 17, 2014
Jazzy chair 600 3 red lights 4 yellow 1 green no power both batteries read 12.5
Lawrence Oravetz
Level 3:
  • Pride Master 10,558 Answers
  • Posted on Feb 24, 2015
Lawrence Oravetz
Pride Master
Level 3:
Answers
10558
Questions
Helped
2699962
Points
29284
Have the joystick controller tested. Make sure the cable is fully seated in the chair connector.
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Apr 03, 2009
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Anonymous
  • Posted on Apr 14, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Anonymous
  • Posted on May 05, 2009
SOURCE: Motor Wiring
Two white wires are for the electric brake.  When the wheelchair is turned off while on an incline, the motors automatically lock up, preventing the wheelchair from rolling backwards.  The white wires disengage the electric brake when power is applied.
oregoon
  • 175 Answers
  • Posted on Oct 22, 2009
SOURCE: Replacing battteries in Jazzy 1103 power chair
Here's a quick link to the owners manual for the 1103 that will show you how to replace the batteries on your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_1103_Ultra_om.pdf
Anonymous
  • 232 Answers
  • Posted on Oct 20, 2010
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
How can I get this chair to work
Pride Mobility Products Download the trouble shooting information for your model chair.
I have 3 red 4 yellow and 1 green, also the speed lights flash only once .
Hi ring this number they might b able to help with youre problem ,,1-800-800-8586.... Cheers
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Replaced batteries in Jazzy 600 but they will not charge up.
doug then you could have received a bad battery or you have a charger problem or a charger circuit problem. If the chair comes on then the wiring is ok. when you plug the charger in do you have a green light and a yellow light on the charger? (when fully charged the light goes from yellow to green indicating full charge) If when you plug the charger in and you have a red and green light then there is a problem with the charging citcuit. I would contact your provider where you got the chair to have them check it out for you Hope this helps
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
2helpful
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
7helpful
3answers
Jazzy 1121 power chair won't go
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
