SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
SOURCE: HTR-6130 will not turn on
Hi
Does the receiver have a switch that allows you to turn off all the speakers?
If so,turn them off and see if the problem stays.
If it still kicks off then , one of the power amp outputs has failed and it will require some fixing
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
