Bosch 24 in. SHU53 Built-in Dishwasher Logo
A
Anonymous Posted on Feb 16, 2014
Model SHE53 will not fill with water, getting error code E21
Kenmore dishwasher model 630.12303314 displays error code E21. What does it mean?
Hello
You try this it may help.
How do I fix error code E21 dishwasher?") Circulation Pump Blocked
  1. Remove any excess water before removing the base of the machine to release the pump.
  2. Check and remove any blockages preventing the circulation pump from turning and Replace if any damage is found.
2answers
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Keep getting E21 code on my Kenwood (K814WM14) washing machine. The washing machine is draining fine, however when filling with water it makes a bumping sound then goes to the E21 code
Is your water pressure fine? Is there water coming out of the waste hose? Make sure that the waste water hose is elevated at 20/30 degree angle. This did the trick for me.
1helpful
2answers
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Front load washer e21
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
1helpful
E2 error code aw-8990st toshiba wash
E21: Lid open
E31: Load imbalance
Hope this helps
1helpful
Frigidaire lft6700fso washer not filling with water
water pump is clogged i pulled it out and cleand it and put it back and its working like it should and the part n is m222-5 on the frigidaire front loader
Its not getting water in. the error it shows is e21
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
