SOURCE: My Movado Series 800 second hand zeroes out at the
The chronograph can be reset by pulling out the crown to the first or second position and pressing the start button or top button. This will begin to move the sweep arm and you can stop it on the 12:00 or 0 position. Make sure that when you have the battery changed they do this for you.
Testimonial: "Thanks for the quick response. I adjusted my watch seconds after I read the email. THis is a terrific service."
SOURCE: my watch battery low
mcdevito75 here, Movado a FINE watch, BEST BET, look for a small watch repair shop in your area to change the battery, Movado watches have a very good over all value and any damage can lessen that value, not to mention the jewelers screwdriver you"ll need to change that battery.
SOURCE: How do I remove a steel link from a Movado
mcdevito75 here, Special tools neede to remove links, Best Bet look for a small watch repair shop in your area, and hold onto those links once removed as you may need them again in the future.
SOURCE: I have a Movado series 800 model 2600075 watch. I
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on it to extend fully and you should be able to change the time at that point.
SOURCE: how do u you set
Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
