SOURCE: Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
SOURCE: Roper washer ras7133kq1will not spin enough to wring out clothes
bad motor most likely. easy fix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
