SOURCE: T60 will not boot up
There appears to be a BIOS update or two available for the Lenovo TP T60. One of the updates makes reference to this error code, but the verbage afterwards is a little different to that posted here. Mind you, my recommendation is that you should stay on target with BIOS updates because they are fixing problems with the computer, even if you don't realise you are having those problems!
Please go here: http://www-307.ibm.com/pc/support/site.wss/MIGR-64462.html
Press Ctrl F and search for 2100. This tells you which update fixed a problem with ERROR 2100: At the bottom of this page you will find that these updates are for all regions. You will also find the link to the BIOS update utility.
My experience of BIOS updates on the Thinkpad range is that you have to undock the laptop prior installing the BIOS update, and ensure the laptop has a constant power support - NOT BATTERY. Ensure you read the on-screen notes carefully.
Hope this helps.
