Water tank is not heating water
Could be one of several issues. MC won't hear if it has low water. Low water may be caused by scaled probe, no water supply or other flow problem. Could be that thermal fuses on element have blown and need replacing. Could be that heating element is burnt out. You will need to do some further basic diagnostics.
SOURCE: Bunn VP-17 Coffee Maker
I would suggest descaling the unit, or replacing your thermostat.
A defective thermostat would not cut out the heater after the water is boiled, excessive scale would render the thermostat ineffective, but not to the extent you describe.
Hope this helps.
SOURCE: bunn cwtf15, water does not heat, ready light on all the time
There is an inline thermal fuse on the right side of the element, check to see, if it has resistance, if not replace.
SOURCE: Getting to hot
The thermostat or tank heater is not working properly. Please get the model and date code located on the bottom of the machine and contact customer service. If your machine is 3 years old or less, it will be replaced free of charge. If you machine is over 3 years old, it will be replaced at a reduced price.
SOURCE: Inave a Bunn VLPF coffee brewer, water is leaking
THe most likely answer is that the tube that leads to the sprayhead is clogged with lime. You will need to remove the spray head wich is located above the brew basket and make sure the holes are not clogged with lime. Use a wire brush to clear them. In the field I would use a deliming spring but you may need to go to a lowes or home depot to find a tool you can use to clear the tube wich is what the spray head screws onto or just goole deliming spring and try to order one off line. It is a long flecible very tightly wound dpring about 14 inches in length or so. www.midstaebeverage.com
