HP Pavilion dv2000t Notebook Logo
Terry Lynn Posted on Feb 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need passwords for fingerswipe
Need to add a New fingerprint...says test...and then im to add a password??? whats that suppose to be
  • 2 more comments
  • Terry Lynn
    Terry Lynn Feb 16, 2014
    ru kidding....i can Not get to Another screen.....
  • Terry Lynn
    all i get is.....Xwindows security.....login Failure!!! over n over n...
  • Terry Lynn
    user name...can only choose between TEST or HOMEGROUP USER$
  • Terry Lynn
    I NEED WINDOWS PASSWORD!!!!!!
justwinwin
Level 3:
Master:
  • HP Master 788 Answers
  • Posted on Feb 18, 2014
justwinwin
HP Master
Level 3:
Master:
Answers
788
Questions
0
Helped
96208
Points
1542
Just in case you can not login using the fingerprint (for example, your finger get paper cut), then you have to use the password, otherwise you can not login. If you need a Windows password removal service, then you can call local computer tech to remove the Windows password. It cost $25 - $50 to remove a Windows password.
1 Related Answer
Anonymous
  • 21 Answers
  • Posted on Feb 24, 2012
SOURCE: I forgot my password to my laptop hp Pavilion dv7, but I can still log in with my fingerprint. How do I reset my password without having to type the old password in? Is there a way I can scan my finge
I met the same difficulty for the previous period,and I know the easy
and effive method that you can use Windows Password Reset Deluxe to solve it
by the Internet,while the used method is following.
Tip1:Download Windows Password Reset from http://www.windowspassswordreset.net and install it on your computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
2answers
I have a new galaxy S5 and i set it up with fingerprint to unlock but it keeps going reverting to password to unlock, how do i get it to stay on fingerprint?
Here is another way to unlock pattern lock for Samsung Galaxy phones, also works with password, fingerprint and PIN. Moreover, no data loss
http://www.youtube.com/watch?v=lw4ueft-t_I
Oct 06, 2014 • Cell Phones
Asking fingerprint password
Is the problem that it is asking for a fingerprint password?
You can skip the fingerprint password and log in manually by typing the sequence of Ctrl + Alt + Delete 2 times. This will let you put in an user and password.
Did someone perhaps set fingerprint password while you were not looking?
How to know my previous password
forget about the old one go with new one
Apr 22, 2010 • Yahoo Mail
I need to password protect my router.
log on to the modem as ADMIN
Add A NEW USER
Then add password for new user
(write down the new user & password info)
save your settings
Test away
Rate Me Please MISTERDJ
How to setup finger print sensor
When you start a machine with a Fingerprint reader for the first time, you will see the following screen when you reach the Desktop. This is the main console for configuring and managing the Fingerprint reader.
Here you can enroll your fingerprint, and adjust your Power-on security settings.
When you click on “Create new passport and enroll fingerprints” you will be prompted for your logon password.
Once you enter your password you will see the main enrollment screen.
You can select a fingerprint to enroll either by selecting the fingertip with your mouse, or by choosing from the drop down list. To enroll, either double-click the fingertip you wish to use, or press the Enroll button
On the left is an animated finger that demonstrates how to swipe. You must swipe your finger three times to enroll.
If your finger is not centered, you will be prompted to move it to the right or to the left. If it’s not able to read at all you will be prompted to try again.
When you swipe successfully, you will see the highlighted portion go to No. 2 for the finger printer to be swiped again.
Once you have swiped three times successfully, the three images merge into one and you are brought back to the main enrollment screen, where the enrolled finger is shown with a red dot.
  • You can enroll multiple fingers.
  • The Enroll button has changed to say Delete. This allows you to delete a fingerprint you have already enrolled. If you used the mouse to click on a fingertip that was not already enrolled, the button would change back to Enroll.
When you click Next you are brought to the Power-on Security screen.
This is also the second choice from the main Fingerprints enrollment screen. Here you can use a fingerprint to replace your Power-on passwords if you are using them.
If you are using Power-on passwords, then select the box at the top. When you click on the Add button, you will be shown a list of the fingers that you have enrolled, and can select which one(s) you want to enable to replace your Power-on passwords.
Once you select a choice from the box, the finger will show up in the list. The first time you restart your machine after this, you may be asked to swipe your fingerprint as well as enter any Power-on passwords you have set. After that you should only be asked for your fingerprint.
  • Predesktop Authentication
    • In addition to the process above, there is a setting in BIOS that must be enabled for a user to be prompted for their fingerprint instead of a Power-on password. The Default for this Setting is “Enabled”, so no change should be necessary. It is in the Security Section under Fingerprint. The setting is called “Predesktop Authentication” Again, the default is “Enabled”. If disabled, a user will not be able to use their fingerprint on Power-on.
  • Security Mode
    • This controls what password will allow a user access to the system if they are not able to gain access using their fingerprint. The default setting is “Normal”. This will allow the use of either a user Power on password, or a Supervisor password instead of a fingerprint.
      The alternative setting is High. This will allow only a Supervisor password to be entered instead of a fingerprint to gain access to the system.
Once you click Finish, you will be brought back to the main Fingerprints screen.
The Create new Passport and enroll fingerprints choice has gone. Replacing it are two new choices:
  • Edit passport and fingerprints
  • Delete passport and fingerprints.
If you choose Edit passport and fingerprints you will be prompted to swipe your finger to confirm your identity
You will then see the password screen. Click next to go to the main enrollment screen.
This is the same screen that appears when you have successfully enrolled a fingerprint.
Here again you can delete or enroll fingerprints
I trust this was helpful and thank you for contacting the experts.
2answers
Forgot Password
Hello there:
If you boot into the safe mode this should let you into the system to do what you have got to do then go to control panel and go to users and just add a new user and leave the password blank this should let you into the system untill you get the password you need
Add password to Creditial manger
Digital Persona, the software installed on your Dell computer to manage fingerprint logon, has designed to be integrated on your Windows Vista computer. The software requires you to create a windows logon password and a admin password for the said software so you can enable the fingerprint log in. If in case your sensor fails, you may log on to your computer by using the traditional keyboard.
2answers
Something about the password..
Your yahoo account only has those three methods of access - one, the password, two, the secret question, and three, the alternate email address. If you forgot the password and the secret question, and you can't get your alternate email address back, you're out of luck - you'll have to get a new email account.
The whole point of the secret question is that it's supposed to be something you could never forget, like a pet's name or something - what was the question you forgot?
Nov 22, 2008 • Yahoo Mail
7helpful
3answers
Forgot my Verisoft Logon Password
Not sure if you got this sorted, but all i did as i couldn't remember my pasword and could only login using fingerprint
go to
Start
type 'CMD'
Right Click and select run as administrator
In the command window type NET USER XXXXX welcome01
Where XXXXXX is your user Name
This will force the change of password, and doesnt mess with Verisoft. Now to confirm it's worked go to
Start
Control Panel
Users
Select Change password
in old password type 'welcome01'
in new type which ever you require as your password, it will accept the change.
This worked for me 100%
Cheers
Alan
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
