Archos 3 Vision Digital Media Player Logo
Ignace Erauw Posted on Feb 16, 2014
Archos 30c playback error on flac file - Archos 3 Vision Digital Media Player
2helpful
3answers
How to play FLAC on my Windows PC?
Well, if you're willing to install one thing, you can use the VLC media player found here: http://www.videolan.org/vlc/index.html
VLC also releases applications for Android and IOS, and nativly supports almost all media file formats. This solution would enable you to use the file in its original format on your computer and not worry about conversion issues.
tip
Watch various videos and unprotected DVDs on ARCHOS 7
The ARCHOS 7 offers customer uncompromised access to the Internet, TV and media content… With its stunning 7 inches amazingly high-resolution screen, 800x480 pixels, and huge disk capacity, it is the best travel company and portable audio/video player you can imagine, which will definitely accompany your travels and holidays in a comfortable and convenient way.
To enjoy videos on ARCHOS 7, you should make sure what file formats are compatible with it, following is the detailed information:
Video playback:
MPEG-4 (ASP@L5 AVI, up to DVD resolution)
WMV (MP@ML, up to DVD resolution) including WMV protected files
M-JPEG (Motion JPEG Video) in QVGA resolution
With optional plug-in (downloadable from your tablet on www.ARCHOS.com):
HD support: MPEG-4 (ASP 720p) & WMV HD (MP 720p)
H.264 up to DVD resolution with AAC
MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound (5.1)
Audio playback:
Stereo MP3 decoding @ 30-320 Kbits/s CBR & VBR, WMA, Protected WMA, WMA pro 5.1, WAV (PCM/ADPCM)
AC3 stereo audio and 5.1 sound files (via SPDIF output of DVR Station)
Flac and OGG Vorbis audio files
With optional software plug-ins (downloadable from your tablet on www.ARCHOS.com):
AAC, AAC+ stereo audio files
Obviously, the ARCHOS 7 supported file formats are limited, if you want to watch you various video files and unprotected DVDs on it successfully, format conversion is necessary. By now, Pavtube Video Converter would be a good assistant for you. It is able to help you convert videos from DVs or camcorders (JVC, Panasonic, Cannon, Sony, etc.), TiVo (*.tivo), DVDs (*.vob), YouTube (*.flv, *.f4v), *.mts, *.m2ts, *.mkv, etc. to ARCHOS 7 compatible format. You can look through its step by step guide as below.
Step 1: Run Pavtube Video Converter, and click "Add" button to load video files to it
Step 2: Select output format for ARCHOS 7
Click on the pull down menu of "Format" firstly, and then select "Archos", after that, all the profiles for Archos will be listed out, here I choose "Archos 5/7 WMV Video (*.wmv) for example.
Step 3: Specify destination folder
Click on the folder icon at the end of "Output" to specify where to locate the output files.
Step 4: Click on "Settings" button to adjust audio and video parameters
Actually, the default settings can basically satisfy your ARCHOS 7, but if you want to have your own changes, you can adjust all the items like codec, aspect ratio, frame rate, sample rate, bit rate, and audio channel in the following window:
Step 5: Click "Convert" button to start conversion
Once conversion is finished, the output files can be found out via clicking on "Open" button with ease. Afterwards, just enjoy them on your ARCHOS 7 freely.
For more: http://www.pavtube.com/video_converter/
on Feb 23, 2010 • Televison & Video
1helpful
2answers
Itunes - is there any way for itunes to pay .flac files? I'd like to be able to download flac files, import into itunes, and stream to apple tv
Yes you can play .flac files in iTunes. Its very easy just download a apple script named "fluke". Download from the following link if you are a MAC user.
http://www.macupdate.com/app/mac/28768/fluke/
It's free for MAC but if you are a Windows user you can try the conversion software dBpoweramp (Free limited version will still get the job done) and download the trial version from the following.
http://www.dbpoweramp.com/dmc.htm
This link also gives some explanation on how to use this program and you can directly install it on your Windows computer.
(In order to open the link just hover your mouse on the link and click)
The following link gives the instructions for using Fluke script for MAC users
http://www.simplehelp.net/2008/06/12/how-to-play-flac-files-in-itunes/
Good Luck!
4answers
I can't play or send FLAC music files to my Ipod. Please help. Thanks
i understood your problem ........The best solution is to use Format Factory software to convert your FLAC music file to any music file format like mp3,mp4,aac,mxmmf,midi,wav....etc..
After converting you can able to play music on your i-pod
If you have apple's I-pod then you requires I-tunes Software to sync the music files to your I-pod....
here i am giving you the link of format factory software enjoy....
http://download.cnet.com/FormatFactory/3000-2194_4-11660921.html
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
What format do videos need to be in for phillips go gear
According to the Phillips website, GoGear can playback the following file types:
MP3, WAV, WMA, FLAC, APE
Hope this helps!
2answers
What picture format is needed on a sylvania smpk8854b
For your Sylvania SMPK8854 MP3 Player
o AUDIO PLAYBACK FORMATS: MP3, WMA
o RECORDING FORMATS: WAV
o VIDEO PLAYBACK FORMATS: FLAC, AVI
o PICTURE FORMATS: JPG, BMP, GIF
Free file converter: http://formatoz.com/
Free manual and downloads: http://forums.cnet.com/5208-7595_102-0.html?threadID=303811
This is a FREE answer, Please Rate Me
Lost my manul for archos jukebox recorder 20 mp3 player/recorder & data storage
Go to the RockBox software site. RockBox is provided freely by an end-user created and supported group and is a wonderfully evolved software replacement for quite a few portable music-playing machines. Your Archos Jukebox recorder is long out of warranty, so there's NO downside in updating it by installing the most current version of RockBox. That will greatly extend the capabilities of your machine.
Then download the RockBox user Manual! That will be your new Archos JukeBox Recorder User Manual. You'll be able to select what you hear by one of two control strategies: File names or by Playlists. You'll be able to adjust playback sound in new and more powerful ways than just using the equalizer. Also it will allow you to control playback "pitch" or speed, so you can hear lectures or books at a higher playback speed. Human retention actually improves when playback speed is increased some. You can print out the RockBox pdf. format manual if you'd like or you can study it on line. Lots of choices.
Good luck with your "obsolete" Archos JukeBox. I actually prefer the earlier models which were powered by four rechargeable AA cells rather than those with the replaceable lithium battery. I know someone who ran one of these continually for more than a year to provide background music, plugged into a wall-wart charger and his sound system. Durable!
John
2answers
Dvd transfer
Download Magic Video Converter from www.isohunt.com and change the video to WMP Standard 8. You don't need 1.25 GB vids for the archos, it's too high a quality for such a small screen.
4answers
Playback button problems
please check what is your firmware version, the latest one is 1.6.23. If it is lower please upodate it by downloading the file from archos website. Maybe it would help
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
