I bought a Netgear Bridge that I want to connect to my router WRT54G.
SOURCE: wireless router connectivity WRT54GS
If you use cable connection, try power cycling the modem and router by turning off the modem and router and turning on the modem first and then the router. Though it is a very simple step it sloves most internet connection problems. If you are using DSL, check with your ISP if you are using PPPoE or just dynamic (it all depends on your modem). IF it is PPPoE, check to make sure your connection type is selected as PPPoE and put in your username and password from your ISP.
SOURCE: how to bridge my motorola 2210 DSL modem & linksys wrt54g router
Try these insturctions. Jump to page 109. http://www.netopia.com/support/hardware/manuals/SoftwareUserGuideV751Clsc.pdf
SOURCE: I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
SOURCE: BRIDGING MODEM AND ROUTER
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Click Here for more info
SOURCE: How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
