Microsoft Wireless Laser Desktop 4000 Keyboard/Mouse Logo
A
Anonymous Posted on Feb 15, 2014
Some of my keys wont work like fav,log out,sleep and my documents
Stay logged in facebook
It seem s that you have two problems, I will address the windows 7 issue. you still need to retrieve your password from Facebook...
it seems that you networks is going into a sleep / hibernation mode. you need to go to the control panel...
power options... advance....
go to sleep.. never.. save and exit.
Tony Mitri
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
tip
An error message informs you that you cannot move or rename the Documents and...
To specify a different folder for the Documents and Settings folder during installation, follow these steps: 1. Run Winnt.exe or Winnt32.exe by using the /unattend option, and then insert the following entry into the Unattend.txt file, where z:\foldername is the path and folder name you want: [GuiUNattended]
ProfilesDir = z:\foldername 2. Install Windows. The path that you included in the Unattend.txt file is used instead of the default Documents and Settings folder.NOTE: This method does not relocate any key Windows components. Use this method if you require only user-specific data to be moved.
After you install Windows XP, to specify a folder other than the Documents and Settings folder for a particular user's data, follow these steps: 1. Identify the user's profile path. You can identify the profile path either by user security ID (SID) or by user path settings. The user SID method is preferred. To identify the user's profile path by the user SID loadTOCNode(3, 'moreinformation'); a. Use the Getsid tool from the Windows Server Resource Kit to obtain the SID. At a command prompt, use the following syntax: getsid \\ComputerName UserName \\ComputerName UserNameFor example: getsid \\windowsxp joedoe \\windowsxp joedoeThe results look something like this: = The SID for account WINDOWSXP\joedoe is S-1-5-21-1708537768-1993962763-1957994488-1003 b. After you obtain the user SID, start Registry Editor (Regedit.exe or Regedt32.exe), and then select the user SID under the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList To identify the profile path by the user's path settings loadTOCNode(3, 'moreinformation'); a. Log on to the computer as the user, and then type set at a command prompt. Note the setting for UserProfile, and then quit the command prompt. b. Log on to the computer as an administrator. c. Use Registry Editor to add the UserProfile setting to the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList d. Click the registry key, and then click Find on the Edit menu. e. In the Find box, type the value of the UserProfile setting, and then click Find Next. 2. In the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList registry key, change the ProfileImagePath value to reflect the new path that you want to use, and then quit Registry Editor. 3. Log on to the computer as the user, type set at a command prompt, and then verify that the path has changed.
Moving the entire folder loadTOCNode(2, 'moreinformation'); NOTE: This method does relocate key Windows components. Use this method only if you require the Documents and Settings folder to be moved or renamed and you cannot use the Unattend.txt file to change the name during installation.
To specify a different folder for the entire Documents and Settings folder, including key system components, follow these steps: 1. Log on to the computer as an administrator, and then create a new folder. 2. In the current Documents and Settings folder, on the Tools menu, click Folder Options, and then click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click to clear the Hide extensions for known file types and Hide protected operating system files (Recommended) check boxes. 4. Click OK. 5. Click and drag all the folders in the Documents and Settings folder to copy them to the new folder, except for the folder for the currently logged-on administrator. 6. Log off and then log back on, using a different administrator account from the one that you just logged off from. 7. Open the Documents and Settings folder again, and then copy the profile of the administrator that you just logged off from to the new folder. This extra step is needed because you cannot copy the profile of the account that is currently logged on. 8. Log off the computer, and then again log on to the computer as an administrator. 9. Start Registry Editor, and then click Find on the Edit menu. 10. Type documents and settings, and then click Find Next. 11. For every registry key or value that contains the original path, replace the value data or rename the value or registry key to the new path.IMPORTANT: You must complete this change in the registry for every instance of the original path, or your computer may not start. It is imperative that you update all registry keys and values with the new path.
12. Restart the computer. You can now safely remove the original Documents and Settings folder.
2answers
I am trying to fav more than 1 page on my brother mfc-255cw printer but it will not let me. Normally after the first page go thru it ask you if you want to send another page press 1 for yes and 2 for no,...
Press menu *2864 within 3 seconds and the machine will say "maintenance" now press 91 and it will initialise. When it has done this press 99 to exit. Should be ok now.
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Wake up system from sleep mode
You might want to try to hit the windows key on the keyboard. What works for me when my laptop is sleeping is to hit the power button, this will bring you to the log on screen
2helpful
Effect of sleep button
Hi a_hedges,
Sleep is a power-saving state that allows a computer to quickly resume full-power operation (typically within several seconds) when you want to start working again. Putting your computer into the sleep state is like pausing a DVD player-the computer immediately stops what it's doing and is ready to start again when you want to resume working.
When a computer is in Sleep mode, the power light is blinking and you get a blank screen like it's turned OFF.
On most computers, you can resume working by pressing your computer's power button. However, not all computers are the same. You might be able to wake your computer by pressing any key on the keyboard, clicking a mouse button, or opening the lid on a laptop. Check the documentation that came with your computer or go to the manufacturer's website.
Hope this helps.
My Acer AX1200 wont log onto windows after it sleeps.
sounds like there is a problem with the hard drive
1helpful
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
1helpful
My desktop in Windows Vista has been "invaded" by a document I previously scanned. The document fills the entire destop with the normal icons partly obliterated. How do I correct this? I tried Systems...
It is just set as the Desktop Picture... Right Click middle of the Desktop and Left Click Personalize... change it there :) Or if you have a Fav Photo... Right Click the Photo and Set as Desktop Background...
My friend used it last night i think she went to her server and yahoo not on screen or favorties
Sounds like she logged out and deleted it somehow. Just go to Yahoo home page and log n there, then set as fav again.
Jun 17, 2009 • Yahoo Mail
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
