Tia The above answer would be helpful but I’m trying to get my dishwasher to drain & this makes the dishwasher do some type of cycle & doesn’t drain at all... pls advise
Just installed a CDW60W16 at my daughters house. worked ok empty but as soon as it was loaded the glass icon lit up and beebs. when I turned it over to take a look at the float switch I noticed that the levelling legs were all screwed in so the base of the machine was sitting on the floor. so when the machine was loaded the pressure switch operated as it was being pushed up by the floor. I unscrewed the legs a few turns to allow an air gap between the floor and base of the machine and all working fine now. on checking the installation instructions it only mentions loosening the legs to level it if required which is wasn't. maybe the manual should give instructions to unscrew the legs a few turns to prevent this
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
