SOURCE: cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
SOURCE: CAN I CONNECT STANDARD AUDIO/VIDEO INPUT CABLE TO DELL DIMENSION E521?
To download video to the computer you will need a fire wire cable. Some cameras will download via USB. The camera end of the firewire will be a 4 pin connector and you will need to check the computer. If its a large connector that would be 6 pin, if it is small like the camera, then 4 pin.
Hope this helps.
