Washing Machines Logo
A
Anonymous Posted on Feb 15, 2014
Water fills up in drum with machine unplugged and water turned off
Ltf2140es3 ... serial#xc62105500
Jorgie the appliance guy
Level 3:
Top Expert:
  • Frigidaire Master 5,639 Answers
  • Posted on Apr 01, 2015
Frigidaire Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1521751
Points
32630
BAD WATER INLET VALVE
5 Related Answers
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Anonymous
  • Posted on Dec 18, 2008
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Anonymous
  • Posted on Jan 05, 2009
SOURCE: Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
ROB
  • 858 Answers
  • Posted on Jul 28, 2009
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Greg Mills
  • 497 Answers
  • Posted on Sep 06, 2009
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Kenmore water keep running will not wash
On many washing machines, there is a water level setting switch. This allow you to adjust the level in the machine to converse water. This switch works on air pressure. There is a small hose inside the outer drum at the bottom of the washer. It is connected to the pressure switch (level setting switch). As the washer fills, the weight of the water compresses the air in the hose until the pressure switch activates. There are two possible failure scenarios; they are both fairly easy to repair. First, the hose could be blocked at the drum entry point by lint or debris. This is a somewhat common occurrence. To check this, unplug the washer. Remove the rear cover from the control panel to access the rear of the switches. Find the rubber hose attached to the level switch and remove it. Blow through the hose to clear it. Reattach the hose and retest the machine. If that doesn't work, you may need to replace the water level switch, It is easily remove and replaced once you have accessed the rear of the unit. You can calls Sears service with the model and serial number of the machine and get replacement parts sent directly to your home.
4helpful
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
10helpful
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
3helpful
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
3helpful
Drum fills withe water when machine is not in use
Can you turn off water to machine? The water seleniod needs to be replaced this lets water in the switch sounds like it's stuck open.
My He3 begins to fill the drum with water (very slowly) after the cycle is done, I have to turn off the hose valves after the cycle to keep this from happening. Any ideas what is letting the water back...
sounds like you have a bad water valve..if water is come in try to unplug the washer if water stop you have a bad control if it keep filling you have a bad water valve
1helpful
1helpful
Drum will not spin
1helpful
2answers
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem
It is possible that the water solenoid is stuck open, sometimes they can be cleaned and yet sometimes they will need to be replaced
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
