First of all you need to check if the driver is installed. To check, click on Start > right click My Computer, click Manage, on the left side click Device Manager > check the right pane, you will see all the devices installed on your machine on that pane. Check if your wireless device is installed properly.
If it has no marks on it on the device manager, you might just need to enable the device itself. Most Dell computers uses Fn+F2 keys to activate the wireless. if it has a yellow mark, just install the driver and you're done.
Hope this works.. Regards...
In Dell Inspiron 1520 Notebook, there is a switch on the left hand side of the laptop to
enable/ disable Wifi. Make sure that it is on and with wireless light activated - Press and hold Fn and press F2 (Fn+F2). This will enable the wi-fi and you will be able to detect and connect to a wi-fi network
Let me know if any further clarification/ assistance is required.
GoodLuck! Dont forget to appreciate the solution if I could have been of any help! CreativeTECH
You can turn on/off Bluetooth and Wireless using the Fnand F2 key. To enable or disable wireless networking, press <Fn><F2>. Turns on when a card with Bluetooth® wireless technology is enabled. NOTE: The card with Bluetooth wireless technology is an optional feature, so the ordered the card with your computer. For more information, see the documentation that came with your card. To turn off only the Bluetooth wireless technology functionality, right-click the area and click Disable Bluetooth Radio. To quickly enable or disable all wireless devices, press <Fn><F2>.
Please refer the page #69 to 74 for complete information on the Wireless and Blue-tooth
is ur WIFI connected thru USB ?
then ur USB is losing power...
check if ur USB setting...
go to Device Manager/USB Serial Bus/USB root hub...
go to each ports one by one....right click on each check properties...check Power Mgt tab....
remove the Tick in the box that says "Allow computer to save power'....
close Device Manager/ Shutdown and restart....
The Wi-FI light turns on when wireless networking is enabled. To enable or disable wireless networking, press and hold the blue <Fn> key and press the <F2> key. The <Fn> key is located on the lower left hand side of the keyboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience. Thank You.
