Green light not working on front next to the orange fast freeze switch/light. How do you change bulb behind green plastic cover.
SOURCE: Freezer will not freeze except when using fast freeze
the electronic controller is faulty,make sure you have been supllied a freezer stat and not a refrigerator stat..
SOURCE: Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
SOURCE: an orange light is on next to the green light on
Normally orange signifys that the machine has been switched into fast freeze , check your controls
