Question about Leapfrog Enterprises Leapfrog Leapster GS Explorer
Green screen on leapster gs won't turn on or off
How do I factory reset Leapster Gs?
  1. Insert a cartridge.Insert a cartridge into the Leapster.
  2. Turn the unit on:Turn the unit on and wait for the log-in screen to appear.
  3. Hold three buttons down simultaneously.
  4. Press the "A" button.
  5. Touch the center of the target:Touch the center of the target that appears with a stylus.
How to reset Leapster GS - Quora
https://www.quora.com/How-can-I-reset-Leapster-GS
Feb 25, 2018 | Leapster Toys
Leapster not working
Bought one used. Need to change names. plug up to computer to try and it installed driver but it won.t open up. Leapster screen says "Do Not Disconnect" Don't know what to do!
Jan 09, 2014 | Leapster Learning System
Leapster GS screen upside down
I would try resetting it. You could also try calibrating the screen. The GS screen has a static orientation, so this seems like a very odd problem.
Leapster Explorer or LeapsterGS Explorer screen is not responding to the...
Aug 16, 2013 | Toys
Leapster explorer cartridge won't fit
You have to make sure it is compatible. There are different types of Leapsters. Leapster 1 and 2, Leapster GS, Leapster Explorer and Leappad. Take it back to the store they may give you a refund or store credit.
Apr 19, 2013 | Leapster Learning System
How do i recalibrate the leapster gs screen stylus and screen
SolutionIf your Leapster system does not respond to the stylus pen, it needs to be calibrated. To calibrate your Leapster system:
  1. Turn the unit on and wait for the sign-in screen to appear.
  2. Hold down the Home, Hint, and B buttons simultaneously.
  3. When the screen changes, press the A button.
  4. Using the Stylus, touch the center of the targets.
Jan 28, 2013 | LeapFrog Toys
The leapster gs touch screen won't work
stacyl316, thank you, your solution worked perfectly!
Dec 29, 2012 | LeapFrog Leapster 2 Learning System
Leapster gs photo screen is green
Take it to best buy dude.I mean how hard cam it be?!?!?!Having something being fixed at best but is like $25-$79.Its easy and how do you do it?Raising money just sell lemonade.
Dec 25, 2012 | Toys
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
I gave my son a leapster explorer about a month now and it's volume just stopped working and it wont hear anything.
there are three basic reasons why the leapster explorer won't bring out sound.
1. Defective speaker
The speaker of your leapster explorer maybe defective, this can make it not bring out any sound. Disassemble the leapster explorer, check the speaker part, test the speaker with a AA battery. If you hear any sound using the battery, then it means there is nothing wrong with the speaker.
2. Loose wire connection
Disassemble the leapster explorer, check the wires connecting the speaker to the board. Check for any wire cut, or loose connection which can cause the speaker not to bring out sound. . 3. Sound IC/Card/Board
If non of the above is the cause of the problem, then it means the leapster explorer is having a defective sound ic/board/card. There is an IC on the board of the leapster explorer which is responsible for sound. If this ic has a shot, there won't be any sound. If this be the cause, I think it's high time to took the leapster explorer to a repairman because this requires skill.
I hope the above is clear. If not, please let me know for further assistance.
Regards.
Aug 10, 2011 | LeapFrog Leapster Explorer Learning Game...
Leapfrog Enterprises Leapfrog Leapster GS Explorer Logo
119 people viewed this question
Top Leapfrog Enterprises Games Experts
Paul Bade
Tom Chichester
Are you a Leapfrog Enterprises Game Expert? Answer questions, earn points and help others
