Kodak EasyShare C653 Digital Camera Logo
A
Anonymous Posted on Feb 15, 2014
Can my kodak dx7590 work as webcam? - Kodak EasyShare C653 Digital Camera
2 Related Answers
Anonymous
  • Posted on Dec 14, 2008
SOURCE: Kodak EasyShare DX7590
I had to send my camera in for a flash repair. It's the only way I could get the flash to operate.
Anonymous
  • 262 Answers
  • Posted on Nov 19, 2009
SOURCE: SD Memory Card
Yes is should work you can used atmost 2GB SD card, but do not use more than 2GB SD card
How do i remove the battery cover from my kodak easy share dv7590
from this manual:
http://www.imaging-resource.com/PRODS/DX7590/DX75A.HTM
is the following statement:
On the bottom panel of the DX7590 are the metal tripod mount (kudos for the use of metal here), dock jack, and battery compartment. The threaded tripod mount is a little off-center and too close to the battery compartment for quick battery changes while working with a tripod. The battery compartment features a locking, hinged door, which slides to the side to open under spring pressure.
1helpful
Will a sandisk 4gb sdhc card work in a dx7590 easy share
The DX7590 works with MMC and SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
6helpful
Just bought this Kodak Easyshare DX7590 used. Radio Shack sold us a 4 GB SD card for it. When we insert it into the camera, it says "Memory card needs formatting". When we try to format it, it...
The 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller with the DX7590.
7helpful
I have an 8G memory card that I cannot get formatted for a kodak easyshare DX7590 from a cannon format. What do I do? I've put it in the camera and told it to format it but it won't.
Get an SD card.
The DX7590 works with SD (and MMC) cards. Your 8GB card is actually an SDHC card and thus will not work. You'll have to stay with cards 2GB and smaller.
I have a DX7590 that won't charge the batteries.
Jeff, you didn't verify the type of battery that you have on your camera, is that the KLIC-5000? if yes then still it will not charged on your dock try to charged your camera using the 5V AC adapter. If your camera will not turn on using the 5V AC adapter or will not turn on using your dock it means the camera is defective and not your battery or charger. You can still contact Kodak repair center at 1 800 665 6515 they will handle your issue.
SD Memory Card
The joystick on my Kodak easyshare DX7590 does not work
Hello, I repair this type of Kodak camera and there is not an easy solution to your problem. It is the down fall of this series as they age. You will be better off to replace the camera than the cost of the repair.
Best Regards, Russell
I need an downloadable operating instructions for my Kodak
Hello, All you need to do is type a web search for "Kodak DX7590 USER MANUAL" and there are plenty of sites to download it as a PDF file for free.
Unable to format 4gb disk
Hello, The problem is the DX7590 does not support SD cards over 2 gig.
3helpful
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
