Canon MultiPASS MP390 All-In-One InkJet Printer Logo
A
Anonymous Posted on Feb 15, 2014
Canon mp390 printhead will not move with cover open
2 Related Answers
Anonymous
  • 13 Answers
  • Posted on Jan 27, 2008
SOURCE: Canon Mp390 print problem
Hi James,
If you have replaced the printhead and cartridges and the problem still occurs then it may be the printhead contacts that are dirty. Get a cotton bud and pure alochol and lightly rub the contacts. But I would expect some sort of print out albeit not a decent one. If the above solution does not work then you may have to speak to canon as it may be a serious problem.
frankzjm
Frank Zhang
  • 191 Answers
  • Posted on Feb 08, 2009
SOURCE: WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
HI I VE JUST BOUGHT A NEW PRINTERHEAD FOR MY CANON MP390 AND I GET THE ERROR WRONG CARTRIDGE ON THE DISPLAY. PLEASE HELP
You could try to reseat the printhead again.
Remove printhead, lower printhead lever, close cover.
Let printer to cycle to alarm condition.
Reinstall printhead.
3helpful
Canon mp390 flashing alarm saying "put in cartridge"
The cartridge in this case is the printhead, not the inks. It's telling you the printhead is bad.
QY6-0054-000 around $60.00
2helpful
2answers
Don't know how to put new ink catrige in my Canon MP390
This solution was already posted by solofixya, Nov 2008
With the machine powered on. Just lift up the entire top portion on the platen unit, lower the front verticle cover and the printhead should come to the correct position to change out the ink tanks, just tilt tanks towards the front of the unit and lift out.
The print head won't move stucked in the middle
Try uplugging the power cord, wait 2 minutes, the plug it back in, the printer head should return to its home position. Let me know if this helps.
CAnnon Smart Base MP390
Try to unclog your printhead, release the printhead from the machine, take hot water in abowl, blow air on the upper black cartridge with an injection tool. At the same time put your printhead in to the bowl. Good luck
5helpful
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
14helpful
2answers
How to change ink cartridge in canon mp390
With the machine powered on. Just lift up on the entire top portion on the platen unit, lower the front verticle cover and the printhead should come to the correct position to change out the ink tanks, just tilt tanks towards the front of the unit and lift out.
2answers
CANON SMARTBASE MP390
Hi ,Sent printer back to Canon workshop.
THANK YOU.
3answers
Hi James,
old marine
old marine
ZJ Limited
ZJ Limited
